Oil Pressure
Can any one cast light on start car oil presh ok turn off start up again oil presh low changed oil and filter already.
that is one of the hardest to read posts I've seen in a while! try searching for oil pressure... must have been asked at least a thousand times...
search would help u but anyway dont take much notice of stock oil pressure gauge not very accurate get your self a good aftermarket one if your fussed.
At start it will read about 70 cold engine then should drop to 20 to 40 normal running and may hit 60 under heavy boost.
otherwise mine is intermitent most of time, sometimes goes to 0.
Thanks bud have oil to top of engine but a bit off putting when gauge does not no what to do will check with second gauge thanks again.
Hi Gubby,
As mentioned on the phone, give Dan a PM and he should be able to give you a price on the Greddy Sandwich plate you need for the aftermarket gauge you have fitted.
Danny DTA
Stu
