any one no what this problem is
hi my zed when running lacks power and ive got some smoke coming out of driver side eghaust dont supose any one noes what it could be plzzz :):)
Depends, could be PCV Valves, Turbo seals or anything.
What colour is the smoke
overfuelling perhaps. check coilpack connector not come off
cant be over filling ive never filled it over 3 quarters full and were do i need to look for the air leak :)
one of the plugs may not be firing due to a loose coilpack connector on top(unburnt fuel gettting through....would give black smoke too). there are six check they are secured an easy check to do
Does it missfire? Going by your previous reply i doubt you would even notice a missfire... Soooooo if its black smoke and lack of power could well be a coil pack or air leak.
well i strat it up put it in drive and then it cuts out unless i put some revs on.
Is it a turbo or a non turbo.
How does it idle?
its auto turbo hasnt long had psi valve replaced
psi valve dont u mean .bar valve :mac1:
Check your wobbly shaft isnt bent?
To be honest mate its best if you took it to someone who knows the zed engine, we could be here for weeks trying to determine the fault.
yeah am gonna take just thought ide see if anyone had any ides for me to cheak first befor i coff out loads of cash onit again :D cheers anyways
