March 17, 200917 yr as the title says "clutching at straws " here with my starting problem but, if any of the belts were slipping on start up could this cause problems when trying to start her up ? Maz
March 17, 200917 yr Maz, check all the fuel lines are not leaking and all the coilpacks are working. Also check the ecu connection is not too loose and not too tight. But i still think its the engine temp sensor.
March 17, 200917 yr Author Pete you are refering to the temp sensor that leads to the ECU right, the one with the two conections and not the one that leads to the temp sensor ..reason I ask is the temp sensor that feeds the temp gauge is knackered , but surely that wouldn´t effect starting starting.
March 17, 200917 yr The reason i say it is that when they become faulty they do the exact problem yours seems to be suffering from.
March 17, 200917 yr Author could the ECU temp sensor be faulty but not kick the auxillary fan in then ?
March 17, 200917 yr not normally no but anythings possible. However i do recommend checking the ecu plug as i have seen all sorts of crazy things happen because of that bugger.
March 17, 200917 yr Author pete I´ll give the whole car a good lookover at the weekend. recheck all the fuel lines, coil packs , change the spark plugs , clean the throttle bodies and also check the ECU plug as that is one thing I haven´t checked. Thanks for the advice , really appreciate it
March 17, 200917 yr its a shame some of the regulars dont seem to be around as they could diagnose things like this in a second
March 17, 200917 yr Author if it carries on like it has been I´ll probably still have the problem when some of the regulars do show up ...but I can check her through and at least eliminate some of the possibilities ....it´s a shame too because ones she starts up she runs perfectly.
Maz
