wheels and offsets again!
:confused:Will these fit fr.8.5x19 45 offset and 9.5x19 35 offset i reckon the front should be 35 offset same as the 19's i'm replacing but the supplier reckons sticking a 5mm spacer behind the front wheels any thoughts please
i think i have seen people fitting similar ofsets before so should be ok but im not sure so im sure someone with alot more knowledge than me will be along soon :)
thanks yassa trawled through all previous threads on this subject looking 4 an answer but couldn't find the answer i was looking for.
Hello mate you would want to add a 10mm spacer to the fronts and they will be a 35 offset. The rears should be fine.
Look around for some wheels that fit without the need for spacers, you will need to extend the wheel studs if you go for 10mm spacers and if you fit hub centric spacers it's only more expense.
Paul
Yep if you have not bought them yet I would get some with the right offsets to begin with. I have a big brake kit and run 35x9 front and rear and I need 3mm spacers at the front to clear the brakes. You can really tell the difference with spacers and no spacers.
