Help removing a stuck bit!
I'm having a real job trying to get my o/s cat off the manifold. I've removed the 3 bolts from the studs but the bugger won't come off. Tried all the usual methods i.e soaking in wd40, whacking it with a mallet and pry bars but it won't budge :headvswal
The engine was out late last year so I don't think it's rust causing it. I'm wondering if the previous owner has used some sort of sealant on it that's sticking it. The n/s one came off easily.
I'm reluctant to heat it, unless I have to, as I'll probably just end up setting myself on fire :mac1:
Anybody have any ideas how I can get it off?
cheers
Dave
should fall of at this point. have you tried undoing the other end and using the pipe to lever it side to side etc! i would get someone to apply downwards pressure to the back end of the cat pipe and then hit with mallet!
Got the bugger off :nana2: Cheers for the tip Hellraiser, worked a treat :duffer:
Yassa, the universal persuasion tool is my weapon of choice mate..lol
