Belts all done, gearbox and diff oil changed which has helped the noise in my gearbox. Still there but certainly quieter. Will see how it develops.
Changed the oil and filter last night and the air filters too.
When driving back from garage it was good, no smoke. When sat idling, it started to smoke but only seemingly from the drivers side bank and only when it started to warm up.
Hopefully it’s stuck PCV valves. Could be turbo oil seals as well but I’m just hoping not as I’ve already spent a lot on this car 😂
Time to do some driving though I think! I’ll take it out for a long run next week and see how we go. Properly get it up to temperature
By
RobHowl ·
Hello, I fitted an electronic boost controller today but forgot to disconnect the standard boost solenoid connectors, doh!
I drove the car trying to set it up and got all kinds of crazy readings.
I went home and realised what i had done and disconnected both connectors.
But now im getting 7-7.5psi only.
Any ideas?
And chance i could have set of the knock sensor when i was getting crazy boost?
Would a knock sensor issue allow safety boost with a boost controller fitted?
