MAF limits
Does anyone know what power a MAF will limit a TT to? Have to start thinking about the mapping side of the conversion and wondered what the MAF maxes out at.
550 bhp i think
On the limit then! If I remove it do I need to go with stand alone managment or is there another (less costly) way?
You can go for the doolz system that Z1 do. And have the Chip to suit i think John dixon would be the best person to talk to
you use a different chip that doubles the MAF reading.
I would have thought it would be easier for you to switch to a MAP system so you can bin the MAF and get a bit more space for the single turbo conversion.
I have the doolz set up but after some thought i will be going for the map sensor once i have the stand alone fitted
Open to suggestions, any links to info on MAP system?
Do you mean stand alone system with a MAP sensor?
Edited by Anthonyd
Just a thought,my dad has a hks fcon vpro set up he removed from his car,that was running a map set up.It would need setting up from scratch but its capable of running cars over 1000hp.You could pm him.(old zed)
