just baught a white 300zx non turbo manual
just wondering is there anything to look out for engine bodywork wise?
cheers
jack
its on a H plate imported in 2003 3.0 N/A quite a bit of service history just been through a service costing ยฃ253 and its being delivered tomorrow
hello and welcome jack, there are a few things to look out for eg sills and rear arches. other then that there pretty robust if looked after!
ย
gaz
has the timing belt been changed on the srrvise history done every 60k i think along with water pump you have no turbos to worry about so as long as oil plugs and filters are regulary done you should have no worries as for the body work it should be fine on a jdm as long as there is no accident damage but keep an eye on usual places like rear arches and sills.One other thing I would recomend any test drive to be taken when car is cold and taken for a long drive checking all buttons gear changes and listen to all noises and not the radio. So enjoy your zed and look after it and it will look after you.
cheers everyone im a panel beater so i had it up on the ramps and not a bit of rust and everything works so i am quite happy with it
