front wheels
hi guys and girls ,
while i was outside the otherday working on a car i looked at my zed sitting there all sad and i noticed that my drivers side front wheel is straight up and the passenger side wheel tilts in at the top not sure if its called camber
well what ever its called what do i need to replace or adjust to fix this
the only thing i could think of maybe its been set up like that for driving round roundabouts for better grip :rofl::rofl::rofl:
matt
hi guys and girls ,
matt
Mine has a bit if this,some twat decided to loosen the front sub frame to help with engine removal!!? So he can`t have lined it back up correctly,casters out slightly too..grrr. :xxx: Getting a 4 wheel set up done helped me.
Edited by santa
ah might be worth looking into thanx
what suspension are you running?
check the hight of each side, might be a shock gone saggy. either that or a worn bushe, loose ball joint or damaged arm.
check every thing under both sides making sure its all straight, tight and dry.
if all thats ok, then take it to get the geo done.
hi mark its all std as far as i know i will have a look at everything and hopefully something will be obvious
