caliper removal
If you remove them your going to have to bleed the brakes. You'll be able to paint them with them still fitted. Use proper caliper paint.
If you are going to remove them for painting you might want to buy the caliper refurb kit. Then you can change the brake fluid and they should be more up to the job.
yeah bud but i wanted to spray them thought it would be easier to remove,how difficult is bleeding breaks?already painted them with hammerite ages ago not really ever been satisfied with results
