Diferent temperatures in the engine
Hi!
Well, I have another...problem...:nana2:
Today when I have arrived to my home, I touch the engine and....SURPRICE...
Left side is cold (FRIO in Spanish...), and the other side Hot Hot...(CALIENTE in spanish):
What do you thing about this?...I think that the problem will be the Intercooler because the hot is over these pipes...
My Zed is decat (not problem with hot from a broken catalytic).
I hace stock SMIC.
throttle balance?
sorry??:confused:
More opened throttle manifold than the one side ??
I don´t understand...:headvswal:headvswal
depending on your boost it could be a seized turbo on one side..and not forgeting the left is served from right turbo and visa-versa for right side
I have separates exhausts, and now I have 0,7 (10PSI) bar boosting.(stock turbos)
I have made 2 proves..
1º. After make 15 milles around 80 milles/hour, the diferent between the 2 sides is High.
2º.After make 10 min around 20 m/hour, stops, (city), the diferent is less..
I am thinking to buy Stillen SMIC with the excuse...LOL
the diference after slow driving will be less because of heat soak from engine..check an intercooler is not full of debri
A friend tells me:
"I think that there is gunk in the water tubes that go to the throttles, one side has hot water flowing through it the other doesn't."
Is it possible?
