is there a how to
Can be tricky id its ur first time but ill run u through it.
Lower the window down half way.
there is a little round plastic cove behind glass, pop this off and take out little screw inside.
now unbolt seat belt from top of door.
now you can take off the cover behind the belt.
on top of the door card under the seat belt panel there r 2 screws so take them out also.
remove the power switches.
take out the little cloth cover inside the inside handle to reveal the 2 screws holding in the handle.
there r i think 3or4 screws around the outside of the door card.
take off the cover around the inside door opening handle.
i think thatll do you.
you can now carefully pop out the card.
i hope i missed nothin but i think thats it.
