Hicas
I am fitting a hicas lock out bar. I can't get the original ends off where they join the bottom arm. I have removed the split pin and nut and the bolt the other side of the bush, anything else need to be done as it won't come off even with a bit of:smash:
what sort of bar are you trying to fit?
does it just replace the rack or is it a 2 part item ( 2arms) that replaces the arms and does away with the rack completely?
or
Edited by silverbullet
You need one of these, about a £10 from Halfords
Jeff TT
This one
