SU carbs
Anyone out there in Zedworld know how to alter the 'richness' on an SU carburettor? My mini is running stupidly lean and I can't remember how to adjust it, any help will be most appreciatedas I am having to drive on choke all the time and it's killing the fuel economy :rofl:
theres an adjustment on the bottom by a fuel pipe if i remember rightly if not there let me know and ill check tomorrow
on the bottom of the carb there is a sealed tube with a nut on the top that you should be able to turn by hand clockwise will richen the mixture{its been years since i last worked on 1}..hope this helps.
Cheers chaps, that rings a bell, doesn't it adjust the height of the needle?
Had SU carbs on a Rover SD1 V8 over 20 years ago, the needles and the needle socket wear and cause all sort of running issues, might be worth replacing them first.
ย
Jeff TT
Just run it for 100,000 miles without changing the air filter :D
ย
That should make it run a bit rich :p
also check the damper oil in the su carb top it gets thicker with age and causes the nedle to stick . the needles and jets wear so first thing would be to replace those and the springs run the car for ten minutes wothout choke and then using either a meter or colour tune if you can fine one check the mixture , adjustment for mixture is unde the carb by throttle tube
