Renault megane scenic problem
My dad has asked me to try and sort this out fort him, his renault megane scenic doesnt pull away smoothly, its kanguroo hoping when u pull away in 1st gear, but its ok once you change up its ok! however it idles fine, if you rev it, its fine, its just when u engage 1st gear and pull away! any ideas!
common prob on the transit (pre 2002), the main one for the tranny is the seal leaks (engine side), and you get oil on the plates that then slowely destroys your clutch and drive plate.
With the Megane I expect there is a contamination in there.
Good point, what year is the scenic if pre 06 reg deffo not dual mass, yes my other car is a Scenic 7 seater :wack:
And we had a 55 plate megane (same engine/running gear as Scenic) that had 2 clutches in it in 4 years and only 60,000 miles.
