advice on one piece prop
sadly the other week my autobox went bang so am now having it converted to manual. is it worth me getting a one piece prop done at the same time? what are the benefits? where do i get one from? how much?
Hey mate they are lighter and stiffer so more turning force goes to the wheels rather than getting lost in turning a heavier prop. It is also a significant weight saving over the original prop.
I got mine from Z1 in the states was about 300 squids delivered. Down side is that if you have worn bushes etc it can accentuate any play in the system.
a one-piece lightweight prop has always been on my wish list - but im close to getting an NA diff - am i correct in thinking that a hybrid TT/NA prop is required for the NA diff and therefore if I wanted a one-piece instead it would have to be custom-made?
Their was a guy on ebay who I think came from the Bristol area who made them to order for £250. Will See if I can find out more.
Paul
thanks paul look forward to seeing what you find out.
Z1 and AMZ both do there 1 piece props in any configuration you require.
Mine is a SWB TT Manual prop with NA rear end.
cheers mate - do Z1/AMZ require you to send over your stock props first, or can you pay extra and not bother? i always get the impression they'll only do it on a return basis.
Yassa try this ebay item number: 220311581823 he has nothing advertised at the moment be you may be able to email him.
Paul
Jimmy that link takes you to a Non turbo propshaft is that the one you got or did you buy the TT version.
Paul
