digital clock
is there anybody near hailsham who has a spare digital clock?
only want to try it as mine is no longer working so just want to connect it and see if it my clock thats dead or something else!!:confused:
if anybody can help it would be much appreciated
thanx
mark
thanx
mark
almost certainly going to be the clock itself... very common problem. AndyP used to fix them - or if you do a search on here and are handy with a soldering iron you can do it yourself!
well i have read tech on this but have no idea where i can get 2 180 ohm 1/2 watt resistors
any help on that 1?
any help on that 1?
That is never the problem. Just resolder all the joints on the board problem is you usually have to do the ones under the display as well, which means it has to come off.
Hi Guys,
So its a common fault for the clock to go off then? Mine has gone off totaly, it came back on the other day but the next morning it didnt come back on again:cry:
Very common fault... still it looks better with the nice boost controller in there :D
not much need for boost controller on a N/A auto though
ahhhh woops ><:x:>
Hi Guys,
Yes, a common problem due to manufacturing defects, I have fixed dozens of them, with 100% success.
One of the fuses in the footwell will be for the clock and a few other things on the same circuit I think.
ok i check them.
thanks
best check everything before i go burning myself with soldering iron lol
