January 19, 200917 yr having just read the latest on my headlight thread, this new issue has come up about running off one relay, is there a good chance it could burn out? and how about putting an in-line fuse on that wire you fitted, would that be an idea?
January 19, 200917 yr I think what Andy ment was that running both lights off of 1 relay might burn it out, putting an in line fuse in the cable wont stop it burning out, what i would try suggesting is removing the power from the drivers side light and re connecting it to the origonal loom, leaving the earth connected to the passenger light. see if you lights still work then, it may just be the earth if thats the case all should be well.......if that is the case then remove the power cable altogether...... If you need talking through it give me a call. Neil
