Just thought I would let u guys see what im having fitted soon, I no its not discreet but I had it cheap off zedworld, Jeff will be fitting it and giving my car the once over before getting it custom mapped, going to be running it at 19psi max, im hoping it will make a huge differance, cant wait.
http://www.temple-tuning.co.uk/index.asp?function=DISPLAYCAT&catid=85
Its a Great boost controller, I used to have the E-01. You have bigger injectors and Intercoolers as well then ? , otherwise dont run more than 14/15 psi max after its custom map.
Yes I have nismo 555 injectors and godspeed ic's, not long had a engine rebuild with forged internals with jwt 530 tubs, rps max clutch, lightened flywheel etc, 19psi should be a pretty reliable amount shouldnt it? At the momment I have boost jets in it running approx 14 psi, this ebc should make a bit of differance dont u think?
remember the difference it made upping the boost from 9psi to 14 psi ....well double it and thats what it will be like ..........with forged internals and 530 tubs IC and 555 nismos at 19psi you should be looking at around 400rwbhp + ....loads of fun :)
take it easy though mate it wil be a different animal when you get it back and can bite you in the ass if it boosts up spins up the tyres unexpectedly in a corner
Cheers mate, its going to be a bit of an animal then, I will take it easy, its quick enough now, let alone the extra boost lol
