Me again.
So I have two questions:
RobHowl ·
Ok after a lot of searching i found this, i could never find anything that actually detailed what each setting was for and the manual is limited.
http://www.fd3s.net/avc-r_install.html
Also note the links at the bottom of the page for diagrams. :D
