Could someone help i've got bit of a small problem in that when engine is cold oil pressure is high but when warm drops to 0 but engine seems to run ok? Any suggestions.
Also linked up a DVD player to the handbrake, handbrake light now not coming on? DVD now removed due to faulty unit. Still no handbrake light with cable removed.
Oil pressure is doing what it should. Sounds like your gauge might be reading out a bit low. They are notorious for it.
Have you checked the bulb?
your oil presure is fine it is normal for it to be high in these conditons and should drop whilst driving to around 30psi when warm
The stock gauge does exactly the same sometimes works fine sometimes dont the stock oil gauges are very inaccurate.
