fuel preasure regulator adjustment?
what preasure to set up on fuel preasure regulator?
at present running on 1 bar boost,stage 3 chip,decat pipes,light flywheel,free airflow...
thanks
Standard pressure should be about 39-41 psi. idling 700-850rpm
you wont need any more than that for 1 bar boost.
thanks
Stage 3 chip? what is the spec on it?
Jeff TT
Jeff TT
Sounds like an e bay job.always seeing a seller on e bay with a "Stage 3 chip" that can work with stock or 440cc injectors and can make 400rwhp :rolleyes:
Jeff TT
thats from ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=170184726867
Description
A Stage 3 chip for all Nissan 300ZX / Fairlady turbos. This chip, married with some other light modifications can achieve up to 400HP. All chips are programmed in house and fully tested. The chip maps fuel and ignition for a SAFE power increase.
To reach the full horsepower potential you will need to have already installed:
Performance air filter / Induction Kit
Performance exhaust system
440cc injectors
The chip will work fine with the stock injectors, but boost should be limited to 14 psi (1 bar). With 440cc injectors the chip enables up to 17psi (1.25 bar) although with the stock turbo only 15 psi will be achieved.
thats from ebay
Description
440cc injectors
Id bin the chip as you have no idea how good the map is.Best off getting one thats been proven.
do you have any links on other chips?thanks
There are some very good sources on this site, try Andy P or JD (johndixon)
Also DTA. All reputable sources. Dont waste money on those ebay jobs u will just regret it.
