Does anyone know how these work exactly and how good they are???
Hi, I assume that you mean for a motorcycle?
I tried a couple of options, and ended up getting this
http://www.eliteelectronics.co.uk/Scala_Teamset_Motorcycle_Bluetooth_intercom.html
You will probably agree that the choice of helmet is a very personal thing for any rider, and it takes a while to get a lid that is just right.
The problem with buying ready installed bluetooth is that most are installed on shit helmets.
In my humble opinion, it would be best to buy the helmet that suits you then retro fit the above kit.
You will see it branded as Midland/Scala/Other. It is all the same, just with different branding for some reason. They also appear to have an updated version just released with a few extra functions, but I will let you check that out.
As for quality, check out the reviews. I have found that day to day/short journeys all is good. They work well, and sound decent. It may take a few attempts to get everything positioned correctly for the best results.
Only downside is on a tour battery life wont hold up to streaming music all day, but if you are a wee bit cheeky, you can plug it into the charger when you stop for lunch. My favourite tactic is to put the helmets in front of the wall outlet so nobody spots the charger being plugged in.
Apart from that they work as advertised.
On the downside now there is no way of ignoring the missus when she is moaning on the back!
