protoj ·
At the beginning i used to tell them thats a Nissan 300ZX.
Typical response. "Thats a Nissan!!!! When Nissan made such a car?"
Well nowadays my answer is this.."Its a Z"
Then they ask me "Made by whom?"
Me: Its made by a Fairlady.
Do I have to give more explanation?
I believe that its better for them not to know what car is it.
What u think?
