protoj · 9 minutes ago 9 min
well been having a bit of a problem with my front wipers for a few days now but they have eventually given up on me. they were giving a bit of a clunking noise when the left the bottom of the windscreen now they have stopped working altogether. also they now move freely when i push them. thinking its just the wiper motor what do you think?
