Who is doing what to their zed.
Ive been working out what i want to do and am going to do to the zed over the winter,
Fit New RPS clutch, poly bushes, prop bearing, cromed headlights, HID kit, full engine bay silcone hoses, polished plenium, spray front bumper and bits around the car, Re do all exterior trim with plastidip,
Thats not including breaking the jap one,
Its never ending..................
Whose doing what else...................?
  • Replies 62
  • Views 2.5k
bodyshop tomorrow for a new front bumper and removal of my spoiler, going for a smooth rear. Also waiting on some stainless steel intake pipes for the engine cant wait:D!
ok heres mine :D but most things have been done already :D
1.need to adjust CAS timing. done, Thanks Andyp
2.find and stop oil leak. (rocker cover im thinking).seems to be cam/crankshaft seals. Done rear main seal
3.new engine mounts. in the post done
4.Find where the hell those wires from the aircon box are suppose to go. (should fix my heating problem, (only wants to come out hot) Done and dusted very chuffed the aircon is working
5.my hazard lights are still not working ive changed the switch twice now, starting to get very annoyed with that.
6.done wheel tracking.
7.Respray. Booked in
8.done Want to fit rear subframe poly bush collars??? in the post
9.tie rod poly bushings done
10.done new shocks in the post. fitted
11. Steering has slight play in it. maybe inner ball joints or outer. (bottom knuckle has play. one steering rack bush is deformed. Checked inner ball joints, they still have blue grease and look new, previous owner must has already changed them) steering rack bushings solved this.
12.done. front&rear lower arm poly bushings. in the post. fitted
13.Done Be rid of detting once and for all.
14.front&rear camber arms. in the post DONE
15.new steering rack bushings. in post. DONE
16. refurb calipers and paint silver. Done
17.fit braided brake hoses& brake brace. Done
18.Replace differential bushings done
19. ---- NA
20 jack up rear investigate location of knocking noise. Done
21. fit/spray stillen front splitter.
22a.nexus engine rebuild: underway woohoooo
Forged pistons (88mm oversize)
Forged rods
Cometic HG
reground crank
skim head
rebore cylinders
555 injectors
555 ecu Courtesy of Andy P
egr bypass
Oil pump
DONE
22b. fit rps max clutch. DONE
23.rebuild turbos. DONE
24 done NA
25. RR
26. Fit uprated bushings to rear traction arm and camber arms, in post. Done
27 fit Uk rear ARB DONE
28.fit tein ha's done
29. fit clutch booster done
30. Modify intercooler ducts
31. longer wheels studs DONE
32. roll arches
33. 330mm discs DONE
34. Fit uprated smic DONE
35. paint timing covers/rocker covers/mild polish cas and rad pipes Done
36. Paint plenum DONE
37. fit nearside steering boot.
38. fit Steering uj Done
39. Replace Centre carrier bearing DONE
40. Replace rear nearside wheel bearing.
41. Fit uprated adjustable tension rods DONE
42. paint timing covers/plenum cover/balance bar/rocker covers/plenum Done
43.indiglo dials/chrome rings/stainless steel plate DONE
44. Conzult/get this thing running right. Done but still a few issues.
45. Install water injection system
46. Fit aftermarket gauges, oil pressure/water temp/boost gauge DONE
47. Fit crome hardpipes.
48. Underseal DONE
49.Fit water adapter and gauge/wire up oil pressure gauge. DONE
50. Fit new o2 sensors
51.fit carbon slam panels
52.fit crome z batt tie down/coil pack bolts/plenum&throttle body strips/stainless wing bolts. DONE
53.replace front tyres for mot.
54. JD 555's chip fitted.
55. fit solid steering pivot bush done
56. buy and fit cobra bucket seats.
57.Buy and fit ebc done
58.fit, innovate LC1 wideband kit. DONE
59. New fpr fitted,
. new rad cap
. new pvc hoses
. temp sensor and connector
59. purchase and fit liehgtwieght propshaft. Done
60. purchase and fit bigger oil cooler.
61. adjust handbrake cable DONE
62. purchaand fit front strut brace. DONE
63. investigate high oil pressure (dodgy gauge maybe) DONE
64. purchase and fit Braided clutch line. GB DONE
65. Fit glowshift gauges, Oil temp/air,fuel/fuel pressure. DONE
65.Fit new Slave cylinder with Dot 3/4 fluid done
66. buy and fit uprated Rad
67.buy and fit series 2 ptu. Done
67.replace diff.
68.Refill diff oil "Kaaz lsd oil" Done... OMFG The old oil was as thick as glue.
69.Driftworks Hicas lock/z1 hicas hose bypass tube. in the post woohoo
70.FIt & spray wings west rear skirt, car booked in for some spray work (roof bars in black too)
71.need to replace rear lower shock bushes in post :D
im replacing bushes at the min
osf lower arm bush replaced and just fitted 4 new tyres
it's having the tension rod bushes replaced and tracking done next week
and thats it until 09!, lol
I went out to the garage just now to start taking some bits off the front, but came back indoors to eat a bar of chocolate as it was too cold. I HATE THE WINTER!
At least you can say you gave it a go, thats all that matters:D :D
Soft as sh1t :rolleyes::tongue:
Yup. Can't stand the cold.
I worked a lot of last winter on it, namely the interior and just really can't be arsed to do anything out in the cold at the moment. I'm not driving it right now, so it doesn't really make a difference.
will you be fitting the apexi yourself Si, ?
im still driving mine a bit , but not much due to the current bush and alignment situation :(
Of course!
Of course!
Hope'd so
i'll be next in line for one early in the new year and also prob asking for some wheel advice (hint ,hint):cool: ;)
My winter project work is as follows....
New A'PEXI filter
New O2 sensors
New Coolant Temperature Sensor (ECU)
New chip (AndyP or John Dixon)
New Boost controller
Replacement brake booster
New HICAS arms
AIV Delete
Gloss black roof bars
New scuttle panel
Yeah, be interesting to see what you'll want wheel-wise. :)
I won't be doing a lot, but hopefully Eliza will be going away for a short while!
It'll make a change, as she's spent most of this year in the same spot!
Which is............
Here!
This shot also shows the extent of the paint peel :(
Looks like someone poured brake-fluid all over it :(
You're not the first person to say this to me, but I'm 100% positive it isn't. Alas it's just a combination of a poor paint job (before I owned it) turbo heat and stone chips. Everytime it rains the water gets under another part of it and eats away at it. I'm sorry to say, but it's going to be a full front end respray :cry: (well a total respray would be nice ;) )
My shell is going to the scrap yard tomorrow morning.
Stripped everything out of it I want.
Engine is on a stand in the garage so I am going to start doing some work on that before looking for a new SWB shell.
wel i'm gonna wash mine as it looks like a skip on wheels, hasn'r been washed for 2 months, used every day for work as well lol, .....running well though :)
Mines at Jimmers getting a turbo repair then it's time to contact Mr Dixon :D
so does mine, i keep contemplating washing it but ive got a bad knee and really cant be arsed
Im collecting bits for Spring time or whenever the weather is nice enough to enjoy it again :)
2 months? thats nothing i think ive wasjed mine 4 times since i bought it.
Mine doesnt see water:nono: polish only:)
