September 28, 200224 yr indicators stopped working fuse is ok where is the relay for them. or is there anything else i should be looking for.
September 28, 200224 yr ive had this, check to position of your hazzard switch, i mean the phsical position of it, not whether its on or off. give it a waggle and see if your indicators start working.
September 28, 200224 yr Your flasher unit could be buggered - like mine was. Look up under the steering column. There's a relay with 3 pins hanging off a metal bracket way up under the dash. Halfords do a replacement for about £9.
