Knock sensor wiring question?
Hi Team,
I've a 1990 TT and I've just stripped the engine. My question is the plug was missing from the knock sensor so I've repaired the wires and just put a single small "lucar" connector. I say single because although 2 wires come from the top the black wire folds up and is taped in against itself.
Is this right or should 2 wires go to the sensor?
If it has just one wire which side does it goto as you look at the sensor?
Any ideas?
regards,
Jase
Its just the 1 wire...from memory the White one goes to the Det sensor and the Black wire is not connected but acts as a shield.
Although I could'nt tell you which side Im afraid without looking and I've removed mine so I cant help further....
oh ok scrap the black wire in the picture then:tongue::tongue:
^^^^^ They are shielded as well mate your right.The outer core is grounded at the ecu IIRC.pretty hi tech for an old motor !!
