earth for headlights
still trying to sort my headlight fault, i think there should be an earthwire by the relay box, however on mine its not there? where should this wire go to? as i explained in a previous thread, my headlights are playing up, one is dim, the other is ok, i have checked the bulbs and they are fine, i also checked the relays, i pulled both relays out and tried swapping them around, both relays seem to be ok as they ok in one of the relay sockets but not the other! any ideas??? hope this all makes sense!
If one is bright and the other dim it would point to a bad earth on that headlamp. I would attach an additional earth directly to the bulb using croc clips and wire just to see if it corrects the problem.
