illuminated rear light panel connections???
My new rear centre light panel arrived today. Its the standard Nissan one that lights up green.
There is about one metre of cable with two huge block connectors at the end (1 female & 1 male) I presume these bridge some connection somewhere, correct?
Where do I plug them into?
Cheers, Dan
did u pay 102 quid for it if so grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr i wanted that lol
but i would say it goes to your sidelights
hmmm, hope not, as I have those 99` spec led rear lights and they are wired up completely different. If thats the way though I will have to wire them to my number plate lights
I've got one and i did that - works a treat bud :)
or if you carnt be arsed you could sell it to me lol
also green is illegal you can only use a red light
or so i was told
Lol Ile risk it, If I get stopped I will just say it was a Factory Option & it was on the car from new
Exactly what i will do to :D Who gives a fvck - its my fvckin car and i want the green light :D
:duffer:lol or just say i didnt even know it lit up:duffer:
if you have male and female connector that goes to the driver side rear light and it goes inbetween the wiring loom and the rear light simpley unplug the loom from the light plug one end into the loom and the other one into the rear light its easy took me 10minutes to fit mine
I've got one of these in green and it's just got through it's MOT with it, would have thought they would said something about it if it was illegal.
I had one on mine standard when imported green nissan one it started to flicker then packed up .I got an inverter from someone on here but it looks diffrent than the nissan inverter but it still doesnt work .Do these el panels pack up or is the inverter ive got not compatable with the nissan panel .
