HID LIGHTS one doesnt always work
have fitted new hids and are really happy with them but sometimes when i come to turn them on the drivers side doesnt always come on first time it flashes and go off but if you turn them on and off a few times it stays on have noticed it seems to be worse when everything is cold any body else have this problem if so is there a fix
Yeh i have the same problem.
Anybody?:(
Symptom would suggest either
(a) a faulty ballast, or
(b) faulty electrics to the headlight wiring loom/connector
The easiest thing to test is whether the ballast is faulty by swapping the ballasts around. If the other light now does the same then you know it's the ballast. If, on the other hand, the same side continues to have problems you may be looking at an electrical problem in the wiring loom.
My money is on the ballast though ...
If you require a replacement ballast (or bulb) and have no luck getting them from the place you bought the HID kit from then let me know as I stock these parts.
Regards,
Dan
99% of the time this is due to poor connections, not always with the new HID kit either, the actual headlight loom is notorious for been troublesome, often the best bet is to run new fused feeds from the battery to a relay and just use the existing cables to swith the very low current relay coil.
You will defo have a better supply and with 100% reliability.
Jeff TT
