protoj · 17 hours ago 17 hr
Hey all
has anyone had their front seat belts replaced? My passenger side one is getting a bit saggy so I'm keen to fix it.
Mine is a series one car with the belts in the door. Anyone know where I can get some replacements? I'm keen on getting new ones if I can rather than second hand ones.
