rear fog lights
can anyone tell me which plug and therefore whice wires are for the front fogs. Can i then connect my rear fogs into this switch
If you want your front fog light swtich to turn on both front and rear fog lights (don't know what mot will think) then you would need to take the feed from the front fogs relay under the bonnet.
Edited by PhilP
Thanks for that I didnt realise it might be an issue on the MOT cani get a switch for the spare one above the front fog switch
I have my rear fog wired up to to the front fog switch could'nt tell you which wire I used though as I just used a multimeter and went through the wires till I found the one that had 12v with the switch on and nothing with switch off.
Pretty sure it was from middle connector.
The reason i suggest tapping into the relay is that the switch circuitry isn't designed to handle the current hence the relay
