Who has a fuel pressure gauge fitted??
Hey all as above who has one fitted permanently? where have you fitted it? how have you fitted it? and what gauge did you opt for?...also any recommendations on a gauge where to put it and fitting most welcome. oh and pictures would be even better....regards Jay
Oh i may choose the option of an adjustable fuel reguator and gauge so any info regarding this welcom too...
Meeee :D i got on wired up inside my car, i plumped in a pressure sender after the fuel filter then wired it threw the firewall to my 3 a pillar pod it works very well :D
Ive got a glowshift digi gauge which reads well had no probs yet :D
I got a pic somewhere hang on.
Its the gauge at the bottom reading 41 psi.
heres the sender, I needed to buy a fuel T piece and two red finishers from demon tweeks, i cut into the braided line then plumbed it in. I just ran the ground to a good earth and the other to the gauge. Easy.
Edited by j1mmytt
Hi Jimmy thanks for the info so quickly, So couple more questions, Can i use any PSI gauge as long as the range is big enough? do i need a specific sender or does it comes with the gauge? im gonna have a gander at demon tweeks now i think.....
I bought the gauge from ebay but i needed a few bits from demon, The pressure senders for most aftermarket applications are within the same range, the only difference is the writing on the gauge i suppose unless there are different tolerances for fuel and oil?. For example you could just but an oil pressure gauge&sender its all relevant and reads the same but why not just buy a fuel pressure gauge & sender? seems like more work fitting bits here and there. Wont set you back much for a good working gauge from ebay anyway.
JFYI you have to get an electrical fuel press gauge, it is illegal to run a direct feed, if you have a crash it could pump fuel into the passenger cell!
