Your Turbo spool up time? Poll
Just curious to see how everyones spool up times vary
Mine seems to take rather long at the moment on stock downpipes :( 3500rpm to get to 14psi i know my ebc needs setting up a bit better, havent really had the opportunity to do so yet :( it does however keep pulling all the way up the rev range, 4th gear feels rapid at top end.
This is all temporary until i order me some 530BB's
:D
Turbo spool time to full boost 10 members have voted
  1. 1. Turbo spool time to full boost
    • 2000rpm
      0%
      0
    • 2500rpm
      30%
    • 3000rpm
      20%
    • 3500rpm
      40%
    • 4000rpm
      0%
      0
    • 4500rpm
      0%
      0
    • Whats a turbo?
      10%
2500rpm with JWT5300bb's, GD manifolds and downpipes.
how mch did the 5300bb's set you back with downpipes mate?
I got them cheaper than I should have done ;).
Can't remember the exact price as I bought a load of stuff all together.
I didn't pay any tax.
Where from? Z1? CZP?
what's your definition of spool up time?
That's a point.
I may have misunderstood the question.
I took it as when the turbo's start to spool. Not when I hit full boost.
That's a point.
exactly, I agree with your understanding, but a poll is no use unless everyone uses follows that rule :)
Was suppose to be to full boost,,,, start again lol
Fook knows then, I haven't hit full boost yet LOL
On the last rolling road I was only running 1 bar as it wasn't fully mapped.
I start spooling up somewhere between 2k - 2.5k rpm.
Ht full boost just before 3500 rpm
i mean desired boost.... Looks about 3500rpm to me. ;)
I meant to say just after 3500 rpm ;)
So what are the guys hitting desired boost at 2500 running ?.
Look back at my old dyno graphs when I had stock tubs, I was hitting desired boost around the same place.
To get desired boost at 2500rpm they must be using good downpipes on stock turbos and stock compression ratio :confused: im running slightly less compression on a cometic HG but i think i can achieve higher boost safely but not until i have the turbos to do it with. Is that how it works?
