LOL What a plonker!!! having read some of the posts, even other 106 drivers cant beleive he had removed it....
He would be the type to buy an electric super charger sound thing.........lol
Gotta laugh.
Fitting a induction kit on the restrictor of the air flow box with the origional air filter still in place in the box.
Then after people explained what he had done wrong, he removed both the air filter and the box and the induction and just left it all open and drove the car.
So from filtering the air that goes into the air filter to be filtered.
He was then sucking all the sh!t into his engine.
As already mentioned EPIC FAIL :)
Even if he had fitted it right does he really believe it would make any fooking difference, what a tool
on a side note, I have just ordered a 20p resistor chip from e bay, apparently will give me up yo 40 bhp. Cant wait :hyper::hyper::dance:
:rofl::rofl::rofl:
I got to this post and then i laughed..
"yeah man, drive it with no filter will be fine. what you should do it go to b&q and get some drainage pipe with reducers on, then link them all together until they fit and then ductape the airfilter on to it. then as a cold air feed use some tin foil wraped around a toilet roll and celotape it to the battery (or super glue, maybe even jb weld if strugling) might need some wd40 spraying in the breather pipe aswell otherwise you will get poisonous gases escaping into the car, and we dont want that do we finally as a word of warning, these airfilters tend to make the pistons catch fire mid turbulence, its ok as usually the fires put out simutanously when the exhaust valve opens (due to air resistance) but repeated use tends to cut holes in the big end bearings and then your con rods might snap." ....
i had to look about 10 times to figure out what the **** he had done, i thought he just plopped it ontop of the pipe at first, and how big is that ****er compared to his engine.
Tool!
he probably drove it into a ditch and burned it alomng with his air filter and Pride XD
