Ksports Brakes pull to left??
Hey guys and girls
I have noticed that when I brake the car will pull to the left momenatrily. When I take my foot off it will pull to the right momentarily.
I thought it might be related to road camber but it seems to be consistent what ever the surface.
All rose jointed suspension units, K sport coilover with 8's and 6's, 8pots at the front with 350mm disks.
Cheers all
mine was doing this and it turned out to be the radiator support bracket goosed
Same set up as me and i do not have any probs. Have you bled your brakes properly??
CM I'm pretty sure the brakes are bled properly, I'll get them checked
Stella what do you mean by the rad bracket was goosed?
i have the front ksports and don't have a problem.
You probably have a knackered rose joint or bush somewhere. It will only need a little play to be picked up by a larger brake setup
I'll get them checked over matey. All the bushes and suspension items are about 1k from new, all new bearings as well.
If you've got wide fronts on it may well be camber of the road being exaggerated... try driving down the centre of the road, and if there's a long straight on the opposite side of the road to rule it out...
