Polymathpm
Everything posted by Polymathpm
  1. feeling a bit dumb, only had my zed 14 years and today i noticed the wheels are sided :/
  2. i will give it a go ty
  3. it is now all the way around all the time, even with the key out, if i tap the binnacle it does move but goes straight back almost as if it is magnetised ?
  4. looks like it`s 1 of them weeks, corrected the power window issue now as soon as i start the engine or put the ignition on the speedo needle goes all the way around past the 180 mark :/, any ideads people ?
  5. perfect, all working, many thank all
  6. hi, my power windows all of a sudden stopped working, drivers side was open and stopped about 2 inches going up and now appear dead, checked fuses all seem ok, any ideas please
  7. a supplier of parts in Leicester had some 30mm core plugs in stock
  8. ...and she holds water again! 7 core plugs changed, 3 inside the bell housing (1 failed changed all 3) and 2 either side of the block. During this time noticed a couple of holes on the exhaust which we are now welding then time for external cosmetic fixes and she is almost for the road
  9. Need a few parts - Rear lights and centre - Rear tail gate with mint stock spoiler or aftermarket supra style spoiler or tail gate with spoiler removed and bodywork corrected
  10. does anybody know the core plug size for the side of the block please ?
  11. We believe we've found the source of the leak which is directly left of passenger side engine mount next to the ac compressor its the core plug nearest front of vehicle with 2 match stick sized holes https://imgur.com/a/SdvAW
  12. https://ibb.co/cJ6du6 https://ibb.co/b8tf7R https://ibb.co/dDtf7R https://ibb.co/cCvGgm https://ibb.co/fn1p1m
  13. Hmm the images didn't seem to work what sites do you use I just tried imgur to link the images
  14. Here she is, japanese import nissan fairlady z twin turbo, de-catted, de-restricted, ram air induction, twin bailey dump valves, 5 inch diameter rage exhaust system, ecu re-map, running @ 418.3 bhp (or was she's probably lost a few over the years)
  15. Thank you, hopefully it's not going to be too much of a headache to find, it's a problem that has been there for quite a while I've just not got around to fixing the car mechanically is sound apart from the water leak, there's a few cosmetics I need to sort out too. Need to get the car right and back on the road again and now is the perfect time to get it sorted ready for the summer
  16. We will have a look at this next week when I have a spare day - - - Updated - - - we will also look at this too
  17. Yes the engine runs spot on but due to loss of water it does not get far before its gets to hot and needs to be switched off - - - Updated - - - Heater matrix hoses are fine the leak is lower than the outside top of gear box
  18. Water is coming out as fast as its going in, we've got the z on a ramp and from looking underneath it seams to be coming from the gearbox bell housing, thoughts to it being the core plug behind the fly wheel. What are the chances of it being that is there any more water pipes that we have missed near by to this area.
