jgphenry
Premium Member
Everything posted by jgphenry
  1. Is there a specific parking area or meeting point
  2. Sorry slow replying to your post - yes returned from the middle east
  3. Update - imported FIC Hubcentric Wheel Spacers, Pair 10mm 5x114.3 12x1.25mm, Part Number: WP5110-66N from Concept Z Performance and thay would appear to have solved the problem. Many thanks again for the advice
  4. Did you fit the spacers front and back
  5. Yes the car has an altitude issue - has an one ground the bulbous end of the hicas arm
  6. Between showers got the wheels of - marking on inner rim 10Jx18J H2 ET 45 which I assume is +45mm offset. As I am having alot of trouble with ride height I increased coil overs 14mm all round. Did not solve HICAS hitting the rim but noise has changed a little !
  7. Yes identical scoring (haven't checked offset markings on inside of rim because of the rain !
  8. Offset I need to measure
  9. Oops first time under the car in years. Yes oil pressure gauge working
  10. 265/35 ZR 18 (93Y) N4 - but no issues before coil overs fitted
  11. The electrical sleeve to the gearbox speed sensor (1991 auto) has split and one wire is severed, everything seems to be working except the HICAS light is on. Has anyone come across this before. I will not have a chance to repair and see what happens for a few weeks but am curious.
  12. The arm of the HICAS is impacting the edge of the rear rims (18”) when operating. The car has been in storage for some time and during that time had adjustable coil overs fitted. Does anyone have any advice on how this can be solved a) increase the ride height, b) fit wheel spacers, c) change rims (want to avoid that one).
