Jessica Janssen
Everything posted by Jessica Janssen
  1. Okay Ill check that out. Thanks - - - Updated - - - How would i find another 300zxtt owner near me?
  2. I check the compression on all the cylinders, the second is not hitting. I tested the line that runs into the Coil pack, there is no continuity(electric charge) running through the lines. Im going to hook up a voltage reader to all three lines tomorrow, to see which of the three prongs is not functioning. Thanks for the advice, and if this doesn't work ZED WORLD here i come.
  3. I posted a thread about my engine not running on all cylinders. Running on 5 instead of all 6. Car runs great on 5 cylinders right now. What I fixed so far: New spark plugs New Coil Pack New PTU checked all the lines that run into PTU-ECU-Coil pack=no issues Still running on 5 instead of 6 cylinders. Any ideas on the next step?
  4. Im trying to get another PTU right now, I believe thats the issue. Traced all the lines no breaks or cracks that I can see. If its not the PTU what would be your next step in trying to figure this out?
  5. I believe your right I checked the line for continuity and there is none.
  6. My engine is only running off 5 cylinders. I have replaced the spark plug, that worked for a bit. Then replaced the Ignition control pack and the spark plug, that worked for a bit. Now there is no electricity going to the ignition coil pack. Lost after this Where does that line go to? How to fix the problem?
