gurps5
Everything posted by gurps5
  1. Looks good mate. Thank you. Going to try the adjustment bolt
  2. Hi all When i start my tt i get a squeaking noise which goes away after a few revs and then it comes back every so often. Pretty sure its the fanbelt/alternator belt. Can anyone tell me how to tighten or replace. I need a step by step guide or pics please. Do i have to strip the radiator to gain acces. Its a z32 1990 auto tt
  3. No smoke showing Ive got an after market dial as well as the original. The after market is showing 0.2-0.4 and the stock dial is showing about 6-9 psi First time ive owned a turbo and a 300zx twin turbo. Is there any other ways to test turbo
  4. Need help. I think my twin turbos need replacing but im not 100% sure. My turbo guage says its pushing between 0.2 and 0.4 bar. Can someone tell me how i can test to see if turbos need replacing. Thanks
  5. Changed fuses...all working now. Thank you all. Will post pics of my car as soon as paint job is done.
  6. Just to add rear wipers work and water does. Just not front wipers
  7. Same colours are interchangeable...i asked nissan. My accessory circuit works...thanks guys. But my wipers dont. On the fuse box front pic above...the m5 plug which is the plug on the bottom left is empty. Can someone check to confirm it is empty just incase i forgot to put aplug in.
  8. Ive taken the fuse box out and can see the relays. Now what can i do to test the relays. I havent got a spare working one to interchange.
  9. Ive taken the fuse box out and can see the relays. Now what can i do to test the relays. I havent got a spare working one to interchange.
  10. Will give it a go once it stops raining and keep you guys posted.
  11. Thank you for such a detailed response. Once i get to the relay how can i test?
  12. Interesting and sounds like a pain... Do you have a picture of the relay i am looking for and any instructions of how to get to it.
  13. Its dry as a babies bottom Yes checked and swapped fuses in drivers well, and two pockets of fuses under hood. Are there any more fuses anywhere? Im thinking short but how can i diagnose locate or confirm this. Checked the cigerette lighter wiring. Ground ok, illumination ok, battery permanent ok, ignition live doesnt work...so im thinking its this ignition wire which runs all of my issues and the issue is further fown this wire...but i dont know what to do now yo test this.
  14. Hi all, New to the world of zx and indeed this forum. I own a z32 1990 tt. I have an electrical issue which has baffled me. Basically when I start the car now, my wipers (front and rear), heating - basically anything on the pod on the left of the steering wheel doesnt work. In addition to that the cigerette lighter doesnt work, nor does the folding mirrors or electrical adjust side mirrors. Also the break light doesnt work when i press the pedal. Although when I have the lights on the first setting break lights do work. I think its an issue with the fuses or the ignition positive wire going to all of these. Any thoughts on how to fix or diagnose. I have checked fuses and switched around but no joy. Im thinking either a main fuse which I may not be aware off or possibly a main wire. Hope you guys/ girls can help
