a1evo
Everything posted by a1evo
  1. Yer didnt think so thanks 4 that will leave em on. Evo
  2. Just after some advise folks have plenum off goin to do a plenum bypass does it matter if i dont drill out the attachments under plenum by throttle bodies just a thought as in tt.net thread advises to do so. Thanks Evo
  3. After driving home the other day when temperatures were hot pulled onto drive put auto box into park and it started beeping as if it was in reverse. After putting in reverse it fails to beep now and the box keeps dropping down instead of up even when revs are fairly low and does not seem to recognise overdrive. Other than that it seems fine so was wondering if maby blown some sensor in hot weather or something. Any ideas chaps will be much appreciated. Thanks EVO.
  4. Just a suggestion but had a very similar problem with a 200sx couple of years back, at a certian point when booting it the car would violently judder to a loss in power. Changed the fuel pump and problem solved. Probaly way of on a zed though. EVO.
  5. thanks for that will have to have a look when i get some time. Evo
  6. just found a picture of engine with plenum off and have highlighted area in green but having trouble attaching this - dont suppose you know how this is done?
  7. no unfortunatly not got digital camera. will try and give better description. if you remove the battery an look from side of car under the silver engine cover [plenum] on the corner of engine (also battery height) can see a bolt looks like it is securing something together, gasket could be in there somewhere that has gone. Was just wondering if anyone got an idea of whats leaking. thanks
  8. been noticing a burning smell when getting out of me Z recently so after a quick inspection in the engine bay noticed what looks like a small oil leak coming from the engine :( . Not very technical but can describe it as closest part of engine to battery. looks like some sort of gasket not sure, was just wondering if it is a common place to get a leak or if anyone else has experienced it. Does not seem to be loosing much engine oil thought. thanks for any help all. Evo
