Lynchmob
Everything posted by Lynchmob
  1. Has anyone got an exploded diagram with part numbers of the outside door handles? can't find one anywhere. Need to know how many pieces it comes in and if you can buy the plastic seal around the outside of it.
  2. Would highly recommend an NA, I get about 25 mpg normally, and a bit more if its mainly on the motorway. plus you can still get it sideways when you want to.
  3. Does anyone know if the centre box section is the same on an NA as it is on the TT exhaust? Cheers
  4. Was me heading back from the new forest with blowing exhaust that I managed to do on saturday
  5. Just paid the £15 this morning from jameslynch100@hotmail.com.
  6. Mine was made December 1994, which i thought was series 4, but has got tweed interior. The seatbelt marks and all the plastic in the car is stamped with the right age markings.
  7. Nice will try him tomorrow. Not sure what a series 2 interior is like, will it go straight into a series 4?
  8. Does anyone know the best placeto get this material as I'm finally getting rid of the tweed interior, but don't want to go for leather/vinyl finish. Also is the suede material easier than leather to stretch round the door cards? Cheers
  9. No these ones are about half the size of the W5W, same type of bulb tho.
  10. They say A13v3.6W on them. Crap picture attached if it helps?
  11. Standard looking zed, no rear spoiler in West Drayton turning off main road, I was in the silver Z that went past you. :)
  12. or rare pearl KL1? but probably KH3
  13. If your car is colour code KL0 then halfords do it, its nissan starburst silver metallic.
  14. My car is a 95 NA and it doesn't have electric/leather seats. Think it was only on the TTs it was standard...
  15. Have unplugged the yellow connector on the back of the IAA unit and tried adjusting the screw on the side of it, butit doesn't seem to change the idle. Not entirely sure why its good to do as the ecu reset should sort the idle out anyway?
  16. Have tried cleaning the IAA out with wd40 and adjusted the screw on the side of it but it doesn't seem to change the idle speed, am I doing something wrong or does it mean the IAA is not working properly? cheers
  17. Just wondering if there is any way of checking if the coil packs are at their best? have fitted new plugs recently but wondered if the coil packs are on the way out? Are they stupidly expensive to replace? Cheers
  18. Just had a look and it was definitely your old car with that front bumper.
  19. First Zed I've seen for about six months. Going into London on the M4 just after Junction 3. Looked good, I didn't wave cos I was in a van going the other way.
  20. Do the hazard lights work? could be a dodgy connection in the light switch pod on the left of the steering wheel?
  21. Re subscribed middle of April, paid via paypal but still registered user? can anyone help? cheers
  22. Once you've removed thefog lamp unit there are four clips for the two plastic covers, one at the top, one at the bottom and two at the sides. If you push the top and bottom ones in carefully you will find the side ones pop out easily, but be careful as the plastic will probably be quite brittle.
  23. Cheers guys, I can get a spanner on to them but then i can't turn it so... bumper is coming off tomorrow! not sure if this will help tho but it will be fun.
  24. How the f*** do you remove the bottom of the airbox without taking the front bumper off? Have taken the top two bolts out but the bottom two are underneath ther rails that run up either side of the box and impossible to get a spanner in there. Anyone done this recently? Cheers
