EternalRenegade
Everything posted by EternalRenegade
  1. Just tried all that; it looks clean but still doesn't want to know. Even checked the voltage from 'B' terminal to earth and got 0.1 > 0.3 v instead of 0.8 so I'm putting my trust in the 'garaunteed' US item 'cos it's all I can find. We'll see!
  2. Thanks I'll try a bit harder.
  3. Yes I saw that somewhere as well. So far I've sprayer loads of cleaner on it but I can't get cotton buts through my gauze mesh; they're only about 1.5mm holes! Anyway I sprayed loads and then tried it but without the air filter for speed but it didn't improve. I guess the filter would slow the air enough for the filament to warm up but that shouldn't be noticeable at 2500 rpm? When it packed up it did go pretty instantly; Zed World thought it would have been a bit more progressive?
  4. OK thanks, that is the answer I was looking for on that bit.
  5. This is the response I've just received from an American company advertising apparently the same thing 'Why does it need remapping if it's the same part number as the one I'm taking off?' 'If you are using the same unit then it doesnt require a remap. but if you are to use it as a modification for a CA18/SR20/RB20/RB25 then it will requre calibration hence a remap. -jdmmodificationsworld' I don't know what those numbers refer to; can anyone enlighten me? Should I go for it?
  6. I'll happily use genuine - if I can find one. No way can I afford new. This is the item I'm looking at on Ebay Item number: 160372328004 which sounds like a straight replacement. If anyone cares to take a look and tell me what they think I'd greatly appreciate it.
  7. OK thanks both; anyone know where I can find one? So far no joy!
  8. Hi all, I'm new on here and for the obvious reason that initially I need some help please. I have a '96 non-turbo 300ZX and the MAF just quit! Can't afford a new one & can't find a s/h one. I've seen a couple of motor factors advertising new ones on Ebay but both say they need fuel/ign retune. Anyone know what this means or involves? Oh and one says that his are made in the USA not China or presumably Lithuania! I need to get this sorted fast and then I'm selling it anyway.
