HEX freak
    Portugal
Everything posted by HEX freak
  1. Yeah..I know that this subject was covered a lot of times around here! I'm in the market for a big brake upgrade; I'm looking for the D2 racing brakes mostly because they're cheap! Anyone here using them?! I've searched as far as I can, but still I got no review from them...anyone have thoughts on this that they want to share?!
  2. Make an ecu diagnostic...probably the ecu water temperature sensor is malfunction or disconnected.
  3. I have a set of 6 subaru 440cc injectors; I've bought them in ebay to some jap guy...great seller. He sells them in packs of six if you want them...you just need to get the newer style injector connectors and slice the injector a little bit :smash: they work flawless, I just bough them because sometimes I do some high speed runs and stock injectors at 100% duty cycle scared me a little bit :mac1: Subaru part numbers: 16611AA101 16611AA100 and if you can get the 16611AA231 they are 480cc according with this web site [http://homepage1.nifty.com/BG5A59D/tips/injector.html] Seller in ebay is theglobesavinggroup...and they pretty cheap if you consider that they are cleaned and flow tested.
  4. They are compatible as long as he uses an apexi power fc.
  5. I use Conzult and a ostrich emulator from moates.net, conzult provides real time map trace (and allows you to datalog...more useful if you're doing road tuning) and you can use whatever program you like to edit your files...just download emulity from http://tunerpro.markmansur.com/ and it will upload any change to the file in real time if thats your will. But this is old school stuff...now you can have both in one package http://home.aanet.com.au/nistune/ I never tried it but i'm seriously thinking in getting one :)
  6. I know a guy with a Saxo that ironed a girl with a freaking remote start!!
  7. I've read that also...but what’s wrong with a stock crankshaft? Its way cheaper that the 1080 Eur?? Pound? You’ve quoted. Wow much would you pay for a rebuild?
  8. A brand new Nismo crankshaft from the states is arround 720USD thats arround 530 EUR or 360 British pounds even with tax and shipping it's really cheap.
  9. VTG Turbos, that’s a completely different league... http://www.autoblog.com/2005/11/27/next-911-turbo-to-feature-variable-turbine-geometry/
  10. VNT turbos only work with diesel engines, high exhaust temperatures kills the VNT mechanism :( I know some guys that tried them on petrol engines and it didn't last long. Plus the vane geometry is vacuum actuated and it needs to be altered to work with a regular wastegate actuator. Plus the lack a true wastegate so correct turbine matching its essential or you may have boost creep, sometimes the use of a external wastegate helps. Garrett makes another design it's called VAT (Variable Area turbine) they come as standard in a PUG 405, but I’m unaware of their reliability. VNT VAT...2 "Wastegate" actuators
  11. Mate my advice...if you already experienced detonation with this chip, don’t try to increase boost. You probably already have a socket, so maybe buying a reputable chip is the best option for you.
  12. Leaner Air fuel ratios and very advanced ignition maps, the timing map is really agressive...i wouldn't run it on my car!! But is kinda common to find such ignition maps with some JDM tuners. Rev limiter set at 7400RPM.
  13. arent those turbos twin scroll? I've also heard that they have VAT(variable area turbine) system ?
  14. Hi all, when changing the flywheel is necessary to replace the flywheel bolts with brand new items? Or can I re-use the old ones? Thanks!
  15. Nice numbers, I've got a similar dyno numbers also with stock boost, but slightly different tuning approach. dyno
  16. http://www.thor-racing.co.uk/files/Blitz_SBC_i-D_manual.pdf
  17. Z31 Turbo »»»» VG30ET VG30DET come in Nissan Cima and leopard I think. It’s a quad cam Single turbo V6 very identical to the VG30DETT, apart from the fact that is Single turbo, single plenum with twin TB's and very different head port design.
  18. American - SAE Europe - DIN http://neptune.spacebears.com/opine/horsepwr.html
  19. if you go the metal route....go with aluminium, stainless steel sucks ;)
  20. you'll need to source 110º silicone bends...
  21. The smoke seems to be white/gray…I don’t notice any bluish tone. Past week I’ve done a compression test and it was ok in all cylinders, so It’s unlikely that piston rings are worn or sticking. I’m using the same oil for a long time. haven’t really checked the PCV valves.
  22. Hi all, My car is smoking really hard when I leave the foot off the accelerator. For example in downhill it makes clouds of white smoke…at least it seems white from the rear viewer. When boosting I can’t find no traces of smoke whatsoever. I recently installed aftermarket downpipes and testpipes…about 300 miles. I checked compression recently and it was within acceptable levels. Boost hold on just fine and the car is performing as “normal”. I’ve checked oil and there is no sign of contamination….the level it’s ok. Water level is also ok and no signs of oil. Anyone care to help?
  23. Cams! Auto Cams...make less power.
