clickdoc
    United States
Everything posted by clickdoc
  1. This is a bit of a long story -- but i need to get all the details out to get an accurate diagnosis -- part one -- after sitting for six months my car 1990 Z32 2+2 has a bit of steering wheel chatter when braking lightly -- not with firm braking -- have the 3K brembo big brake kit -- part two -- after driving quite fast (45 mph) threw water i did not see on the road the power steering seemed to disappear -- drove like a tank (like when your steering knuckle is bad) -- went to local mechanic -- i was suspecting the speed sensitive connector on the rack might be loose after the impact with the water -- went to a local mechanic -- drove it into the bay -- I play with the connections on the speed sensor circuit while he is turning it lock to lock in both directions -- he diagnosed bad outer tie rods -- get it off the lift -- power steering is back ! PS the steering knuckle on mine was good. The questions: Was is the speed sensor circuit or did turning it lock to lock unbind something ? Will out of round tires due to the car sitting cause steering wheel chatter with light braking ? Will bad outer tie rods cause steering wheel chatter with light braking? thanks for your knowledgeable help!
  2. I have them -- they work great on the butt dyno !
  3. This is a bit of a long story -- but i need to get all the details out to get an accurate diagnosis -- part one -- after sitting for six months my car 1990 Z32 2+2 has a bit of steering wheel chatter when braking lightly -- not with firm braking -- have the 3K brembo big brake kit -- part two -- after driving quite fast (45 mph) threw water i did not see on the road the power steering seemed to disappear -- drove like a tank (like when your steering knuckle is bad) -- went to local mechanic -- i was suspecting the speed sensitive connector on the rack might be loose after the impact with the water -- went to a local mechanic -- drove it into the bay -- I play with the connections on the speed sensor circuit while he is turning it lock to lock in both directions -- he diagnosed bad outer tie rods -- get it off the lift -- power steering is back ! PS the steering knuckle on mine was good. The questions: Was is the speed sensor circuit or did turning it lock to lock unbind something ? Will out of round tires due to the car sitting cause steering wheel chatter with light braking ? Will bad outer tie rods cause steering wheel chatter with light braking? thanks for your knowledgeable help!
  4. I have them & they seem to be as good as they say
