Pambos
    Cyprus
Everything posted by Pambos
  1. i would like some help, i thought i would give a try on the multipliers reels for surfcasting or general casting and i want to know what reels do you use? cheers
  2. Pambos replied to a post in a topic in General Discussions - Non 300ZX
    the only reason that hookers and drugs are legal in holland is because they dont wann loose the govertment tax on them prostitution and drugs exist everywhere shouldnt make a difference if are legal or not
  3. it depends on the work, if u want work on heads, plenum, extrude honed... then is much more they dont have any parts lying around they do more sales overseas than local
  4. fully prepare engine by JUN!! You are looking at aroung 15-20k without the tubs
  5. Doesnt require an ecu upgrade?
  6. not exaclty the pistons and rods of JUN are the same as the ones sold seperately regardless the volume increase, the crank is developed from scrath it's not a shave of and the weight is around half of the original talking to the director at JUN this kit is good for serious hp 800+ there is a cossworth here with a z engine running 9s in the 400m and it has the kit
  7. Had some overheating last week and removed the rad and the shroud, it seems that the upper water pipe needs replacing doing that i noticed that the rad and and the engine had a lot of rust, it seems my mechaninc fill the car with water only and not antifreeze i will spray some water from the upper pipe to try to clean the engine a bit, but is there something else that i can pour in also?? cheers
  8. that's in boxes of 24! they are the best if you ve notice the they ve got much more gas than the others
  9. yeah i must be blind
  10. ???
  11. Hi mate any decent (dont know how you call them in the UK) shops that bore the cylinders to fit bigger pistons can make you one if you are in a hurry they will take a round steel bar bore it at the ends to fit the existing rear wheels bars so they dont have any play or movement and add to brackets were the existing are to mount it cheers Pambos btw your inbox is full
  12. yeah but in tha range there are far mote important things than headlighs, you can get intercoolers or even turbos from Z1
  13. Any news on these Chris???
  14. this one is when win get stucked. my problem is that the win log off, the screen goes black but the machine still on, wating for me to pust the power buttom in order to turn it down
  15. I ve got a pc with the following specs amd 4400+ xms 3500 2gb paired ram asus a8n32 sli mobo 2 maxtor 250gb rate 0 disks 1 raptor 36gb for the operating .... .... i'm running on win xp version 2002 SP2 (original cd) my problem is that when i shut down the pc, it closes all the app, it locks off win but the machine does not shut down anyone knows what settings must be modified?
  16. yeah i ve got access on the forum, to be honest i ve read the whole thread that's why i was asking where did you get yours from. let's hope that everything works out with your set
  17. where did you got the inserts from???
  18. Paul ask for Ouzo you'll love it
  19. Pambos replied to a post in a topic in General Discussions - 300ZX Related
    i also have 5 apexi all electronic with the memory, warning futures
  20. i think on the skyline is electronic you simply remove the plug but not sure if the r34 works the same way
  21. DTA has the ally version dont know whether they have them in cf
  22. Pambos replied to a post in a topic in General Discussions - 300ZX Related
    order a pair of Ganador yesterday i'll post some pics when they are on the car
  23. take it for a spin and you'll be good to set it after
  24. what about Luke cant he copy one for you?
