Easy007
Everything posted by Easy007
  1. Thanks for all the welcomes chaps. So i can see that the bottom arms are very similar to my 180sx Setup but i'm a little confused by the top 'arm'. Is there a ball joint on the top of the hub or is it at the top of that long cast silver thing i can see in the pic below? Actually looking at the pic again is it some kind of spherical bearing between the hub and the cast arm? The shock mount on the hub looks useful as i shall be using Short coilovers with an eyelet top and bottom. How does the rack attach to the hub? is it infront or behind like my 180? A good question..... it's going on a Nissan D21 drift truck with a full custom chassis. My chassis man wants to use the D21 hubs with some custom arms but i'm trying to figure out if i can use something more standard for when i inevitably bend something and need to replace it.
  2. Hi my names Nick and i'm just popping over from the SXOC as i have a few questions i need help with, if you don't mind. I am about to start on a new project and need help with my front suspension setup options. I have been informed that the Z uses twin wishbone front susp which would help me massively as i won't be able to use a Mcpherson strut setup on my truck as i won't have the room, and will also help me get the correct pcd for my wheels. Has anyone got a pic of the front suspension on a car without a wheel so i can hopefully see if it will be of any use to me? Sorry if non of this makes sense......
