For some reason my window goes down but not up :confused:
Now my windows is stuck all the way down and will not go ak up!
I have taken the door trim off but cannot fine the blackbox, that i see sometimes causes the window problem.
Could it not be the switch mate?? Down button working, but not the up one? Is it the drivers a pass side? If it's the pass side, then try both switches, if it works on one, it's ya switch, on the drivers side you only have one switch (obv), but that's the first thing I would try matey... HTH.
Thanks for the info :)
I have tryed another switch and the drivers side but no joy, its the passanger side thats not working.
Just strange why the windows goes down but not up, only problem is the window is stuck all the way down now :cry:
Ah well mate, that's not a problem I've ever had to deal with (yet :-) But I'm sure when all the Zed geniuses get home from work, they'll see ya right matey. Best of luck pal...
i mind i thought my window was F***** but then realised i had bumped the P/W Lock button, was quite funny after i had stopped swearing at myself.lol
To get yourself out of trouble for now, remove the door panel and reverse the motor connections and then do the down button again but this time the window will go up, not a fix but will at least will close the window for now.
Jeff TT
I had a problem last week with the electric windows. It may be a different fix as yours is the passenger window, but my drivers window would sometimes work fine, then it would suddenly just not go down. Then it would go down, but not back up again.
My issue was down to the window amplifier assembly (Black box situated behind the door trim under where the arm rest would be). It had brittle solder contacts on the main connector. Resoldered them and job's a good 'un. No longer have the problem.
Thanks everyone :bow: Will go and have a look to see if this is the problem, for know I just switched the wires over to make the window go up.
