Me again.
So I have two questions:
RobHowl ·
Have a knocking noise coming from engine, starts at at about 3200rpm, disappears about 500rpm later. Anyone got any idea what might cause this?
It seems loudest from oil pump area. The oil pump is only 2K miles old.
Scott
